How do I change the orientation of a BEAM188 element when I have generated the element directly (i.e. without using lines or LATT command)?
April 13, 2023 at 7:33 am
Solution
ParticipantThe EMODIF command can be used to modify directly-generated elements’ nodal connectivity or attributes. You can use the EMODIF command to change the orientation of a BEAM188 element even if you do not have lines associated with it. Simply create the orientation node and then use the EMODIF command and include the orientation node when redefining the nodes on the beam. The attached input file demonstrates this.
1. 2025558.zip
- ANSYS Mechanical: Node Merge
- ANSYS Mechanical: Node Move
- Is there a way to show the element coordinate systems so that I know what direction the bending moments are in?
- How to use ANSYS Workbench Meshing Virtual Topology
- I am getting an error that mixed order mesh elements are not supported. How to overcome this issue?
- How can we apply different loading conditions on both the top and bottom of a shell/surface body, e.g., temperature on top face and convection on bottom face.
- How to use ANSYS Workbench for Shell Meshing and Editing
- How can you identify the element types used by Mechanical?
- What is the difference between shell 63 and shell 181?
- How to use ANSYS Workbench for Merging Mesh Nodes
