Tagged: 17.2, fluent, fluent-post-processing, fluid-dynamics, post-processing
March 17, 2023 at 1:10 pm
SolutionParticipantPlease follow the steps below: 1) Click Report → Force to open the Force Reports panel 2) In Options, select Moments 3) Enter the coordinates of the center point of the rotation for Moment Center 4) Select the Wall Zones that will serve as the plane of rotation from where the torque will be calculated 5) Print will appear in the Console Window
1. 2041541.pdf
- Skewness in ANSYS Meshing
