January 25, 2023 at 7:16 am
FAQ
ParticipantWhenever you have interface zone with boundary nodes exactly at the same location (matching boundary nodes within tolerance limit) in MDM problems with non-conformal interface, use the following rpsetvar command to prevent Fluent from merging the boundary nodes before creating non conformal interface: (rpsetvar ‘ nonconformal/force-shared-nodes-to-boundary 0) Default value of the rpvar is 1
- Skewness in ANSYS Meshing
