June 6, 2022 at 9:58 am
FAQParticipantThe problem is due to a small gap between the line bodies. To identify the gap, use Boolean > Unite. Select all the line bodies and unite them. You should then see that some of the bodies are not merged together. Zoom in closely at the end points to see the gap. Use Tools > Connect to connect the end points.
- ANSYS Mechanical: Node Merge
- Is there a way to show the element coordinate systems so that I know what direction the bending moments are in?
- How to use ANSYS Workbench Meshing Virtual Topology
- I am getting an error that mixed order mesh elements are not supported. How to overcome this issue?
- ANSYS Mechanical: Node Move
- How can you identify the element types used by Mechanical?
- How to use ANSYS Workbench for Shell Meshing and Editing
- How can we apply different loading conditions on both the top and bottom of a shell/surface body, e.g., temperature on top face and convection on bottom face.
- What is the difference between shell 63 and shell 181?
- How to change begin node and element number for meshing in Workbench Mechanical?
