How come I don’t have the option to select manual source and targets for a sweep method applied to multiple bodies?
January 25, 2023 at 7:16 am
FAQ
ParticipantThe Sweep mesh method does not support the Manual Source, Manual Source and Target, or Manual Thin settings for Src/Trg Selection if Sweep is applied to more than one part. If you put the bodies within the same part (i.e. to enforce shared topology) the a single sweep method could be applied to multiple bodies.
- Skewness in ANSYS Meshing
