June 6, 2022 at 9:58 am
FAQ
ParticipantThe procedure is as follows:
– Generate the 3D solid Mesh
– Using ESURF command, create SHELL281 elements on 3D solid elements
– solve your model
– Calculate surface stresses/ strains as required in output
- Does ECAD trace mapping support more than one type of trace material (usually copper) in the same layer?
- How can I understand Beam Probe results?
- ANSYS Mechanical: Fatigue Crack Growth Analysis using SMART Crack Growth
