Structural & Thermal
How can you use surface elements to get the surface strain data?
    • FAQFAQ
      Participant
      The procedure is as follows:
      – Generate the 3D solid Mesh
      – Using ESURF command, create SHELL281 elements on 3D solid elements
      – solve your model
      – Calculate surface stresses/ strains as required in output
