How can you project surfaces/curves onto cylindrical surfaces without changing their overall dimensions?
June 6, 2022 at 10:33 am
FAQ
ParticipantThe imprinted shape will sometime deteriorate if the projection is in the normal direction.
Use the wrap operation for this purpose.
1. Go to “insert” tab
2. Select “Wrap” operation
3. In the options guide select “imprint as edges”
- How to reverse surface normal in SpaceClaim?
- How to Change the Direction of the Normal Vector of the Internal Face?
- ANSYS Workbench: Decomposition and Hex Meshing – Part I
- Create Sections in Meshing
- ANSYS ICEM CFD: Basic Blocking
- Tip on exporting geometry in Parasolid, STEP format from DesignModeler
- How can I create a 2D section from a 3D model in SpaceClaim ?
- How do you turn a rectangular surface mesh into a triangular surface mesh?
- What is meaning of message: One or more objects may have lost some scoping attachments during the geometry update.
- What is the difference between patch dependent meshing and patch independent meshing?
