June 6, 2022 at 9:58 am
FAQParticipantDuring a solution, Mechanical writes a solve.out file that contains the element types used in the model. You can directly open the solve.out file using a text editor or access it from within Mechanical via Solution Information option under the Solution Object. You need to select Solution Information and set the “Solution Output” to “Solver Output”. You can then search the solve.out file for the element type section. It will begin shortly after a header something like:
*** SELECTION OF ELEMENT TECHNOLOGIES FOR APPLICABLE ELEMENTS ***
The element type listing will look something like:
ELEMENT TYPE 1 IS SOLID186. KEYOPT(2)=0 IS SUGGESTED AND HAS BEEN RESET.
KEYOPT(1-12)= 0 0 0 0 0 0 0 0 0 0 0 0
- ANSYS Mechanical: Node Merge
- Is there a way to show the element coordinate systems so that I know what direction the bending moments are in?
- How to use ANSYS Workbench Meshing Virtual Topology
- I am getting an error that mixed order mesh elements are not supported. How to overcome this issue?
- ANSYS Mechanical: Node Move
- How to use ANSYS Workbench for Shell Meshing and Editing
- How can you identify the element types used by Mechanical?
- How can we apply different loading conditions on both the top and bottom of a shell/surface body, e.g., temperature on top face and convection on bottom face.
- What is the difference between shell 63 and shell 181?
- How to change begin node and element number for meshing in Workbench Mechanical?
