August 25, 2023 at 12:16 pm
SolutionParticipantThis is currently not possible through the Mechanical GUI. However, you can accomplish this through the use of a commands object as described in the attachments. Also, consider using a smaller unit for time as an alternative to using very small numbers.
1. 2044670.pdf
