How can we rectify error while simulating bolt pretension simulation ” THE PRETENSION LOAD WAS NOT ABLE TO BE APPLIED. & MAKE SURE THE LOAD WAS NOT APPLIED TO A HOLE AND THAT & THE LOAD IS NOT APPLIED MORE THAN ONCE PER SURFACE” ‘
June 5, 2023 at 7:04 am
FAQ
ParticipantThis issue comes when there is some issue with geometry which cause this error.
- Does ECAD trace mapping support more than one type of trace material (usually copper) in the same layer?
- How can I understand Beam Probe results?
