How can we apply different loading conditions on both the top and bottom of a shell/surface body, e.g., temperature on top face and convection on bottom face.
January 25, 2023 at 7:34 am
FAQParticipantANSYS utilizes the SHELL131 element to apply a load on layered shell data; this enables the application of loads to either the top or bottom of a given shell/surface body. The exposure of this element is directly available in ANSYS Workbench-Mechanical as a Beta feature. You can activate this in three steps: 1. On the WB project page go to Tools > Options > Appearance > scroll down and check the Beta Options box. 2. Then, in Tools > Options > Mechanical > Beta Feature Selection check the box labeled “Allow thermal variation along shell thickness”. *note: you will have to restart Workbench (save your project and close Workbench and reopen it) for this feature to take effect within Mechanical 3. When you open Mechanical, under Geometry, select your surface body and for the setting “Thermal Variation (Beta)”, choose “Linear Variation”. With those steps executed, when you apply a given load, under the Details box, a new field exists named “Shell Face”. You now have the additional option of choosing the top or bottom face though that field.
- ANSYS Mechanical: Node Merge
- Is there a way to show the element coordinate systems so that I know what direction the bending moments are in?
- How to use ANSYS Workbench Meshing Virtual Topology
- I am getting an error that mixed order mesh elements are not supported. How to overcome this issue?
- ANSYS Mechanical: Node Move
- How to use ANSYS Workbench for Shell Meshing and Editing
- How can you identify the element types used by Mechanical?
- How can we apply different loading conditions on both the top and bottom of a shell/surface body, e.g., temperature on top face and convection on bottom face.
- What is the difference between shell 63 and shell 181?
- How to change begin node and element number for meshing in Workbench Mechanical?
