How can the following error be avoided? Details of error:- —————- Error detected by routine MAKDAT Illegal data area length CDANAM = NCOMPT CDTYPE = INTR ISIZE = 0 CRESLT = SIZE Current Directory : /INTERP/SOLUTION/DST/VX +====================================================================+ | ****** PROBLEM REPORT ****** | |——————————————————————–| | Subsystem: Input and Output | | Subroutine name: ErrAction | | Severity level: Fatal Error | | Error message number: 001100279 | |——————————————————————–| | Message: | | | | Stopped in routine MEMERR | | | | | | | | | | | +====================================================================+
March 17, 2023 at 8:57 am
FAQ
ParticipantThis error can be avoided by clearing the Solution cell in Workbench (LMB on Solution, RMB and select “Reset”) and rerunning the case.
- Skewness in ANSYS Meshing
