Tagged: 2021 R1, fluid-dynamics, General, system-coupling
June 5, 2023 at 7:06 am
FAQParticipantTo create and open just Mapping results in EnSight, 1. Start systemcoupling.bat -G -m cosimtest 2. Once the case is setup, in command console enter “Initialize()” 3. Once mapping is done, enter “WriteEnSight(FileName=’Mapping’)”. FileName can be anything. This writes EnSight results to Mapping folder adjacent to SyC folder. 4. Open the results from Mapping folder in EnSight.
- Skewness in ANSYS Meshing
