3D Design
3D Design
How can one export only the face of a solid in DesignModeler?
    • FAQFAQ
      Participant
      This is not directly possible, but the user can create a surface from the face using Concept//Surfaces from Faces. And then suppress the solid and finally export the geometry. You should be able to delete the created surface and unsupress original solid.
