August 25, 2023 at 12:15 pm
SolutionParticipantDescription: Sometimes it is useful or desired to generate a .def file from a CFX component system in Workbench (WB). CFX-Pre in WB does not provide a direct option to write a definition file. Is it not possible to write a def file from a WB project? Solution: Writing a def file in WB is possible. This is illustrated in the attached pdf file.
1. 2048652.pdf
- Skewness in ANSYS Meshing
