June 6, 2022 at 10:32 am
FAQ
ParticipantIn the Meshing tool bar, click on ‘Annotation Preferences’; turn on the checkbox “Plot Elements Attached to Named Selections”. Click OK. Now you would be able to view the surface mesh (if the underlying entity is meshed) once you select the Named Selection in the Outline panel.
- How to reverse surface normal in SpaceClaim?
- How to Change the Direction of the Normal Vector of the Internal Face?
- Create Sections in Meshing
- ANSYS Workbench: Decomposition and Hex Meshing – Part I
- Tip on exporting geometry in Parasolid, STEP format from DesignModeler
- ANSYS ICEM CFD: Basic Blocking
- How can I create a 2D section from a 3D model in SpaceClaim ?
- How do you turn a rectangular surface mesh into a triangular surface mesh?
- What is meaning of message: One or more objects may have lost some scoping attachments during the geometry update.
- What is the difference between patch dependent meshing and patch independent meshing?
