Tagged: 19.1, chemkin, Chemkin General, fluid-dynamics, Other
August 25, 2023 at 12:16 pm
SolutionParticipantWhen a Chemkin simulation fails to complete for any reason, you can still get (Rate-Of-Production) ROP information up to the point where the simulation stops. The catch is that you must use either the PSR model or the PFR model. If there is a flaw in the chemical mechanism, as is often the case, this is not problematic, however. Both PSR and PFR models have an option to print ROP data to the text output file. Please refer to the attached document for the details
1. Solution_2055313.pdf
- Skewness in ANSYS Meshing
