Tagged: 19.2, fluent, fluid-dynamics, General, General - FLUENT
April 5, 2023 at 2:32 pm
FAQ
ParticipantAn easy way to check this would be to input the following as an execution command into Fluent: mesh/size-info This will print the number of cells to the TUI each iteration (or time step), so you can see if it’s changing.
- Skewness in ANSYS Meshing
