Tagged: 16.2, CEL, cfx, fluid-dynamics, General, General - CFX
January 25, 2023 at 7:16 am
FAQParticipantThe usage of hybrid or conservative values are controlled by the ANSYS CFX Solver automatically. If you use algebraic Additional Variables (Boundary Only) maybe necessary to have explicitly control which values are used. In ANSYS CFX you can use operators in the CEL Variable.Boundcon returns Hybrid Values Variable.linlin returns Conservative Values Temperature is an extra case. On walls or CHT interfaces Temperature returns usually the hybrid values. There is an extra variable called Wall Adjacent Temperature to access the temperature See also ANSYS CFX Reference Manual: Chapter 16.1. Hybrid and Conservative Variable Values
