Tagged: 18.2, fluent, fluid-dynamics, General - FLUENT, udf
April 5, 2023 at 2:32 pm
FAQParticipantTo stop a run based on a certain condition, you can set the number of iterations for the run to zero, by calling the integer RP variable that carries this information. This should stop Fluent more elegantly than a bailout. To do this you have issue the scheme variable RP_Set_Integer command to set the value of ‘sol/iterations’ to 0 so that Fluent thinks the run is over, ie: RP_Set_Integer(“sol/iterations”,0);
- Skewness in ANSYS Meshing
