How can I solve an electrical conduction problem in which my materials have anisotropic electrical conductivity?
April 13, 2023 at 7:33 am
Solution
ParticipantTo do this, create a user-defined scalar transport equation for electric potential. This equation will have only a “Conduction” term. Setting up this equation will require a conduction-type property to be set for each material. This property represents the electrical conductivity and is presented as “uds-conductivity” in the property listing for each material. The options for this material include anisotropic specification. Please see attached document for setup details.
1. 2064590.pdf
- How do I model humidity in Fluent?
- I am running an electrochemistry simulation in Fluent. How can I access the electrochemistry reaction rates with UDF?
- ANSYS Internal Combustion Engine (ICE): Port Flow Part 1 – Getting Started
- Model setup: Setting up chemical reactions
- ANSYS Fluent: Describing Non-premixed Combustion using the Steady Flamelet Model
- How do I use the Flamelet Generated Model?
- ANSYS Chemkin-Pro: Reducing a Combustion Mechanism
- Explanations on the warning Maximum / Minimum PDF table enthalpy exceeded in xxx cells (Non-Premixed or Partially-Premixed models)
- How can volume fraction be plotted in a species transport simulation?
- Configuring and Solving the Chemical Species Transport in Fluent
