March 17, 2023 at 1:11 pm
Solution
ParticipantAttached document describes the steps to set anisotropic thermal conductivity in solids in ANSYS Fluent Keywords: Anisotropic, Heat, Conduction, local coordinates, UDF
1. 2058960.zip
- Defining heat transfer coefficient (HTC)
- Thermal Analysis of a Radiator Using Ansys Fluent
- Simulating Battery Pack Cooling System Using Ansys Fluent
- How to solve the warning: “Warning: zone of type interior found between different solids!”
- How to add comments to journal file so that I will know what each entry does?
- In ANSYS Fluent, when the energy equation is enabled and viscous heating is enabled, must pressure work also be turned on?
- ANSYS Fluent: Overview of the Mapped Interface Technique for CHT Simulations (18.2)
- How to use Thin Walls with Thermal boundary conditions?
- ANSYS Fluent Student: Conjugate Heat Transfer in a Heat Sink
- What is the difference between internal and external emissivity?
