April 13, 2023 at 7:32 am
Solution
ParticipantWhen post-processing large cases it can be useful to run CFD-Post remotely on a Linux machine with large memory and using the Window session only for the dispaly. Attached is a step by step guide on how to set this up.
1. Solution-runnning_CFDPost_remotely.pdf
- Skewness in ANSYS Meshing
