How can I resolve the following error in Forte 19.2? —- Error Message —- 1 validation errors detected in project: =============================== Problem detected in Open Boundary Restriction Discontiguous inlet surface detected for a single boundary condition: h2inlet01 are not connected. =============================== The above issues must be resolved before the simulation can be run ——————————
Tagged: 19.2, fluid-dynamics, Forte, General, parallel, Run Execution
March 17, 2023 at 8:58 am
FAQParticipantThere are some surfaces that are disconnected. There is a defect in Forte V 19.2 where the the surface checking algorithm fails for certain hole topologies and identifies them as problematic when they are not. The issue is resolved with the 2019 R2 release.
- Skewness in ANSYS Meshing
