Tagged: fluent, fluid-dynamics, General - FLUENT, Other
June 5, 2023 at 7:05 am
FAQ
ParticipantWhen using a text file created by Windows such as UDF or Chemkin format file on Unix, it rarely works correctly. Many of the problem is the character code problem, when you use the following command in the Unix side you can convert the Windows character codes to Unix character code. dos2unix *** *** Is the name of the file.
- Skewness in ANSYS Meshing
