How can I prevent my Workbench Fluent runs from saving .cas and .dat files if I only want to extract a single image or images?
June 5, 2023 at 7:06 am
FAQParticipantRun Fluent with a journal file that issues the exit without save command The Fluent TUI under Workbench gives access to following command. /file/close-without-save This command prompts for a y answer to confirm the exit, so the journal line would be: /file/close-without-save y
- Skewness in ANSYS Meshing
