Tagged: 19.1, General, mechanical, structural-and-thermal, structural-mechanics, transient
April 13, 2023 at 7:32 am
SolutionParticipant1. Insert a temperature and change “scoping method” to “Result File Item”. 2. In “Solver Component IDs” input “MASS71” Attached is an example
1. 2054741.zip
