Tagged: 19.1, General, mechanical, static, structural-and-thermal, structural-mechanics
April 13, 2023 at 7:32 am
Solution
ParticipantInsert following command under Structural Analysis and then insert user defined function “TFSUM” OUTRES,NONE OUTRES,ERASE OUTRES,ALL,ALL See attached example
1. 2054716.zip
- Does ECAD trace mapping support more than one type of trace material (usually copper) in the same layer?
- How can I understand Beam Probe results?
