March 17, 2023 at 1:11 pm
SolutionParticipantANSYS Fluent allows anisotropic thermal conductivity for solids but not for fluids. However, certain flows require accounting for non-isotropic thermal conductivity, for example due to the presence of disperse, oriented particles at molecular level. In such situations, it is possible to mimic this effect by introducing a porous media with no drag to modify the effective thermal conductivity. The attached document describes how to setup a simulation to model air flowing through a channel with anisotropic thermal conductivity.
1. 2058672.zip
2. S_2058672.pdf
- Defining heat transfer coefficient (HTC)
- How to use Thin Walls with Thermal boundary conditions?
- ANSYS Fluent Student: Conjugate Heat Transfer in a Heat Sink
- How to solve the warning: “Warning: zone of type interior found between different solids!”
- ANSYS Fluent: Overview of the Mapped Interface Technique for CHT Simulations (18.2)
- Setting Operating Density for Natural Convection cases when density is modelled using Ideal gas law
- How do I get rid of convergence problems with energy equation in Fluent (especially since R15)?
- In ANSYS Fluent, when the energy equation is enabled and viscous heating is enabled, must pressure work also be turned on?
- Thermal Analysis of a Radiator Using Ansys Fluent
- In Fluent, how can we reduce the time for an unsteady simulation of a Conjugate Heat Transfer (CHT) simulation? Is there any way to give different time steps for fluid and solid in a single simulation?
