June 5, 2023 at 7:05 am
FAQ
ParticipantWhen performing a transient run in parts with one or more solver restarts, several case_001, case_002, … case_00n folders and case_001.res, case_002.res, … case_00n.res result files will be created. If it is desired that all trn file in all case_001, case_002, … case_00n folders are loaded in cfx pre then proceed as follows: In CFD-post, when loading the last result file case_00n.res, under “Case options” select: “Run History and multi-configuration options” “Load complete history as”: “A single case” Then all trn files from all previous transient runs will be also loaded.
- Skewness in ANSYS Meshing
