June 5, 2023 at 7:04 am
FAQParticipantQuestion: I have a plate structure with many tiny holes. The holes are not important in the analysis. Is there a way to mesh over them instead of going back and removing in the CAD model or ANSYS DesignModeler or ANSYS SpaceClaim? Answer: If the size of the holes is very small compared to other geometric features of interest, then, in the Details view of the “Mesh” branch in Workbench Mechanical or Workbench Meshing, you can set “Automatic Mesh Based Defeaturing” to “On”. Specify a “Defeature Size” value that is larger than your hole size. Any edge lengths less than this value will be ignored by the mesher. Please note that, if you have important geometric features smaller than this Defeature Size, they will also be ignored, so please use this with caution. Otherwise, holes will need to be removed or filled in. For example, ANSYS SpaceClaim does have extensive select capabilities to select several similar entities and operate on them quickly, including using the FILL tool.
- ANSYS Mechanical: Node Merge
- Is there a way to show the element coordinate systems so that I know what direction the bending moments are in?
- How to use ANSYS Workbench Meshing Virtual Topology
- I am getting an error that mixed order mesh elements are not supported. How to overcome this issue?
- ANSYS Mechanical: Node Move
- How can you identify the element types used by Mechanical?
- How to use ANSYS Workbench for Shell Meshing and Editing
- How can we apply different loading conditions on both the top and bottom of a shell/surface body, e.g., temperature on top face and convection on bottom face.
- What is the difference between shell 63 and shell 181?
- How to change begin node and element number for meshing in Workbench Mechanical?
