June 5, 2023 at 7:05 am
FAQParticipantTo the macro that you are using, the pointer of the thread (zone) you want to access may not be included in the argument, so you can get a pointer using the following macro: Lookup_Thread (domain, zone_ID) and domain pointer, do it giving Zone_ID, corresponding to the ID, you can get the thread pointer. In addition, THREAD_ID (T) can get the Zone_ID from the thread pointer.
- Skewness in ANSYS Meshing
