How can I get the nominal section properties for a given section, rather than the ‘derived’ properties (Area, Iyy, Iyz, etc.)?
March 17, 2023 at 9:00 am
FAQParticipantThe *GET,,SECP command can be used to find the actual input values. For example, *GET,,SECP,id,DATA,nnn Where: id = the section identification number nnn = the location in the SECDATA command for the given section id number
- ANSYS Mechanical: Node Merge
- Is there a way to show the element coordinate systems so that I know what direction the bending moments are in?
- How to use ANSYS Workbench Meshing Virtual Topology
- I am getting an error that mixed order mesh elements are not supported. How to overcome this issue?
- ANSYS Mechanical: Node Move
- How can you identify the element types used by Mechanical?
- How to use ANSYS Workbench for Shell Meshing and Editing
- How can we apply different loading conditions on both the top and bottom of a shell/surface body, e.g., temperature on top face and convection on bottom face.
- What is the difference between shell 63 and shell 181?
- How to change begin node and element number for meshing in Workbench Mechanical?
