How can I get a single fluid cell zone in Fluent from a geometry which was decomposed into several parts in SpaceClaim?
August 25, 2023 at 12:15 pm
SolutionParticipantThe parts must be combined in a single named selection “fluid”, or they will be assigned to different zones in Fluent. Please see the attached resolution document for details.
1. 2052237.pdf
- Skewness in ANSYS Meshing
