How can I extract the points from a curve in SpaceClaim? I would like to export them to a .csv file and also produce an image of the result
March 17, 2023 at 1:10 pm
SolutionParticipantThe SpaceClaim Curve Tool under the Details tab can be used to do this. Please see the attached ducument for details
1. 2061643.pdf
- Skewness in ANSYS Meshing
