Tagged: 2019 R1, General, mechanical, static, structural-and-thermal, structural-mechanics
January 25, 2023 at 7:34 am
FAQ
ParticipantThe Surface Coating provides a method to extract the deformed faces of a body: 1. Insert a Surface Coating and select desired faces for extraction. 2. After solution, you can extract the deformation results based on the Surface Coating option. 3. Hide all other bodies except the Surface Coating, and export result using .STL file option. 4. Set the display option to Result only.
- Does ECAD trace mapping support more than one type of trace material (usually copper) in the same layer?
- How can I understand Beam Probe results?
- ANSYS Mechanical: Fatigue Crack Growth Analysis using SMART Crack Growth
