March 17, 2023 at 8:58 am
FAQParticipantFor exporting data of a part in ANSYS EnSight, use File > Export > Geometric entities > Flatfile Then select the desired part and make sure the requested variable is active, before you export the data. Also, only Node based data will be saved to the flatfile. If you have only access to Element data, such data can be transformed to Node data using the ElemToNode function in the Calculator tool box. Keywrords: Flatfile, Export, CSV, Ensight
- Skewness in ANSYS Meshing
