Tagged: 2020 R2, fluent, fluid-dynamics, General - FLUENT, parallel
March 17, 2023 at 8:59 am
FAQParticipantUser can easily define Report Plots and Report Files before running the simulation. However, sometimes user may decide to export the plotted data during/at the end of the simulation. Because Fluent stores this data, it is possible to do so with the command /plot/file-set/plot-to-file [filename] After running 1 iteration, Fluent will dump all data used in all the plots into the specified file.
- Skewness in ANSYS Meshing
