Tagged: 2019 R1, fluid-dynamics, General, icem-cfd, Solver output
April 13, 2023 at 7:32 am
SolutionParticipantANSYS ICEM CFD 2019R3 (19.5) cannot export WIND files out of the box. However, we would like to make the WIND Output Executable available to our customers via the ANSYS customer portal. Please copy the file wind.exe to the folder C:Program FilesANSYS Incv195icemcfdwin64_amdicemcfdoutput-interfaces You find the WIND Output Interface, as before in ICEMCFD under the tab Output Mesh, Select Solver, Output Solver -> WIND After writing the file under: Write Input -> WIND The following message appears in the Message Window: Current solver is WIND Solver WIND supports multiblock mesh and unstructured 3D mesh. Select an unstructured domain. Done with translation.
1. 2059063.zip
- Skewness in ANSYS Meshing
