Tagged: 2019 R2, fluid-dynamics, General, icem-cfd, Solver output
April 13, 2023 at 7:32 am
Solution
ParticipantANSYS ICEM CFD 2019R3 cannot export Fire V8 files out of the box. However, we would like to make the Fire V8 Output Executable available to our customers via the ANSYS customer portal. Please copy the file firev8.exe to the folder C:Program FilesANSYS Incv195icemcfdwin64_amdicemcfdoutput-interfaces and the file python25.dll into the folder C:Program FilesANSYS Incv195icemcfdwin64_amdbin You find the Fire Output Interface, as before in ICEMCFD under the tab Output Mesh, Select Solver, Output Solver -> Fire_V8 After writing the file under: Write Input -> Fire_V8 , The following message appears in the Message Window: Running ICEM CFD – FIRE V8 Interface Vers. 15.0.0 … done. Done Done with translation.
1. 2059061.zip
- Skewness in ANSYS Meshing
- How can I select interior faces and other entities that are inside the model?
