June 6, 2022 at 8:32 am
FAQParticipantTo enable the EARSM model based on the K-w formulation:
1) Enable beta features
/define/beta-feature-access yes ok
2) Enable the KW-BSL-EARSM
/define/models/viscous/kw-wj-bsl-earsm? yes
- Skewness in ANSYS Meshing
