How can I define a parameter and assign it to an input variable using the FLUENT TUI (Text User Interface) ?
Tagged: 2019 R3, fluent, fluid-dynamics, General, General - FLUENT
January 25, 2023 at 7:16 am
FAQ
ParticipantIn latest versions, the parameters have to be defined using Named Expressions (with the appropriate units). Therefore you will only be allowed to create parameters using the Named Expressions TUI menu : /define/named-expressions/ For example, to create a parameter for a gauge pressure on a pressure outlet boundary condition: 1) Create the Named Expression and define it as a parameter: /define/named-expressions/add “my_gauge” definition “0[Pa]” parameter yes q 2) Assign the expression to the proper boundary condition: /define/boundary-condition/pressure-outlet outlet yes no “my_gauge” …. (actual full command depends from the models activated)
- Skewness in ANSYS Meshing
