April 5, 2023 at 2:33 pmFAQParticipant
Use the command EEXTRUDE to generate the 3D finite element models from the planar model
- ANSYS Mechanical: Node Merge
- ANSYS Mechanical: Node Move
- How to use ANSYS Workbench Meshing Virtual Topology
- Is there a way to show the element coordinate systems so that I know what direction the bending moments are in?
- How can we apply different loading conditions on both the top and bottom of a shell/surface body, e.g., temperature on top face and convection on bottom face.
- I am getting an error that mixed order mesh elements are not supported. How to overcome this issue?
- Structural modeling with ANSYS Workbench Mechanical
- What is the difference between shell 63 and shell 181?
- What might cause the “Error: HResult E_Fail has been returned from a call to a COM component” in SpaceClaim?
- Why would I get non-zero force reaction in X direction in 2D axisymmetric model?
