June 6, 2022 at 10:33 am
FAQParticipantYou can cut the geometry with any plane (as per your requirement) and then copy(CTRL+C) and paste(CTRL+V) the surfaces. Then, Suppress the solids for Physics and leave surfaces active, so as the active surface parts are transferred to Mechanical. For axisymmetric model, you may have to move the geometry before slicing with the plane, so that the geometry is on the XY plane. Before you launch Mechanical, please make sure to set the analysis type to 2D in the Project Schematic page.
- Create Sections in Meshing
- Tip on exporting geometry in Parasolid, STEP format from DesignModeler
- How to reverse surface normal in SpaceClaim?
- How to Change the Direction of the Normal Vector of the Internal Face?
- ANSYS Fluent: Watertight Geometry Meshing Workflow
- ANSYS Workbench: Decomposition and Hex Meshing – Part I
- ANSYS ICEM CFD: Basic Blocking
- How can I create a 2D section from a 3D model in SpaceClaim ?
- What is the difference between patch dependent meshing and patch independent meshing?
- Fluent: Watertight Geometry Meshing Workflow
