How can I convert relative humidity into a mole fraction that can be used as BC value at inlet boundary in Fluent?
Tagged: 16.1, BCs & Interfaces, fluent, fluid-dynamics, materials, reaction, Species/Reactions
January 25, 2023 at 7:17 am
FAQParticipantThe steps below explain how to convert relative humidity value into mole fraction, which can be entered as a boundary condition value 1) Relative humidity = 100 * Partial pressure of vapor in air / partial pressure of vapor in air at saturation 2) Partial pressure of vapor in air at saturation = saturation pressure of water at the cell temperature 3) Using 1) & 2), you will get partial pressure of vapor in air 4) As per Dalton’s law of partial pressures, partial pressure of vapor in air / total pressure of air = mole fraction of vapor 5) Mole fraction can be specified as an input at the inlet BC in the species tab.
- How do I model humidity in Fluent?
- Configuring and Solving the Chemical Species Transport in Fluent
- ANSYS Fluent: Describing Non-premixed Combustion using the Steady Flamelet Model
- ANSYS Internal Combustion Engine (ICE): Port Flow Part 1 – Getting Started
- Model setup: Setting up chemical reactions
- How do I use the Flamelet Generated Model?
- How can volume fraction be plotted in a species transport simulation?
- ANSYS Chemkin-Pro: Reducing a Combustion Mechanism
- I am running an electrochemistry simulation in Fluent. How can I access the electrochemistry reaction rates with UDF?
- Explanations on the warning Maximum / Minimum PDF table enthalpy exceeded in xxx cells (Non-Premixed or Partially-Premixed models)
