Tagged: 19.1, fluent, fluid-dynamics, General, General - FLUENT
April 5, 2023 at 2:32 pm
FAQParticipantThere is no simple way to do this that is already built into Fluent. It is possible to write a translator. This will require a reader to understand the xml format, including all of the possible property definitions (e.g., ideal gas, piecewise, polynomial, etc). You then need a writer to turn it into a Fluent User Database. If this is a one-off sort of task, then the simplest solution is to copy-paste the properties over. If this is a recurring need, then perhaps it’s worth pursuing the above approach.
- Skewness in ANSYS Meshing
