Tagged: 16, cfx, fluid-dynamics, General - CFX, post-processing
March 17, 2023 at 8:58 am
FAQParticipantThis is controlled during the definition of the line objects themselves by modifying the number of sample points. This is available in “Samples” under the Geometry tab when the object is created. By using, for example, 50 points on a line 50 cm long, and then 83 points on a line 83 cm long, you ensure consistent representations between the two lines.
- Rocky GPU Buying Guide
- Skewness in ANSYS Meshing
