June 6, 2022 at 8:33 am
FAQ
ParticipantQ: How can I compare the eddy dissipation model rate with the chemical reaction rate in the ‘Finite Rate Chemistry and Eddy Dissipation’ turbulent combustion model in CFX?
A: For any reacting flow model, the overall rate is available in CEL and post-processing as..Molar Reaction Rate. To output, in addition, the separate ..Eddy Dissipation Reaction Rate (i.e. the rate from the EDM) and the ..Chemical Reaction Rate (i.e. finite chemistry rate) you need to add the CCL to the Solver arguments:
-ccl short_rules.ccl
where short_rules.ccl contains:
LIBRARY:
VARIABLE: edmrate
Option = Definition
Output to Postprocessor = Yes
END
VARIABLE: kinrate
Option = Definition
END
END
- How do I model humidity in Fluent?
- I am running an electrochemistry simulation in Fluent. How can I access the electrochemistry reaction rates with UDF?
- ANSYS Internal Combustion Engine (ICE): Port Flow Part 1 – Getting Started
- ANSYS Fluent: Describing Non-premixed Combustion using the Steady Flamelet Model
- Model setup: Setting up chemical reactions
- ANSYS Chemkin-Pro: Reducing a Combustion Mechanism
- How do I use the Flamelet Generated Model?
- Explanations on the warning Maximum / Minimum PDF table enthalpy exceeded in xxx cells (Non-Premixed or Partially-Premixed models)
- How can volume fraction be plotted in a species transport simulation?
- LES Simulation of Turbulent Flames Using ANSYS Fluent
