Tagged: 18.2, fluent, fluid-dynamics, General - FLUENT, post-processing
August 25, 2023 at 12:16 pm
SolutionParticipantThis is done with a right-click on the tabs of the monitor plots. (Please see attachment: right click on the tab, ie on the “Scaled Residual text label in this case.) The right-click exposes a drop-down menu that shows the various layout options. The “Tabbed View” is the default option, and is shown in the attachment. The “SubWindow View” is an alternative which shows the monitors in a smaller “tiled” layout. The “Full Screen” expands the “Tabbed View” and hides the rest of the Fluent interface.
- Skewness in ANSYS Meshing
